SUGAWARA Roundness measurement device BWM-102 and SWA-31
Makes high-speed, high-precision measurements of the surface waviness of a rotating ball.
For download the full Bearing Inspection System brochure please click here
Waviness is measured either by fixing the workpiece and rotating the sensor or by fixing the sensor and rotating the workpiece. We use the latter method. Waviness is evaluated based on the value obtained after passing through a band-pass filter. The lower area of the band contains the evaluation of the shape, while the higher area contains evaluations of roughness. Various bands are used according to the intended bearing application. The following units are used to quantify waviness:
| ?Wcla: | Micron Wcla |
| Mean value of waviness displacement in ?m | |
| ?m: | Micro meter |
| RMS value of waviness displacement in ?m | |
| ?inch: | Micro inch |
| RMS value of waviness displacement in ?inch | |
| ?PC: | Mu PC |
| Integrated absolute values of waviness displacement in ?m | |
| ?m/rad: | Micrometer per radian |
| RMS value for waviness displacement differentiated with respect to central angle |
Yoichi MORI – Group Leader, The Export Sales Group
Sugawara Laboratories Inc.
8-2 Minami-Kurokawa, Asao-ku, Kawasaki-shi,
Kanagawa, Japan  215-0034
Tel: +81-44-989-7320
Fax +81-44-989-7338
Email: [email protected]
Web: www.sugawara-labs.co.
